18 Dec 2008 at 21:39 #21 demon8991 demon8991 Soldato OP Joined 7 Jan 2003 Posts 4,458 Location Gold Coast, Australia How does this look? The multiplyer changes obviously depending on useage.
18 Dec 2008 at 23:00 #22 MeatLoaf MeatLoaf Soldato Joined 1 Dec 2005 Posts 14,838 Location Stoke on Trent demon8991 said: How does this look? The multiplyer changes obviously depending on useage. Click to expand... Looks fine, have you tested it with orthos? Have you disabled speedstep in the BIOS? I have on mine and it still seems to kick in, alternating between 2.5 and 3.8Ghz
18 Dec 2008 at 23:17 #23 Banjo Banjo Associate Joined 13 Apr 2007 Posts 172 Location Wolverhampton MeatLoaf said: Have you disabled speedstep in the BIOS? I have on mine and it still seems to kick in, alternating between 2.5 and 3.8Ghz Click to expand... Have a look in the BIOS for a setting for C1E and disable it Harri
19 Dec 2008 at 10:25 #24 demon8991 demon8991 Soldato OP Joined 7 Jan 2003 Posts 4,458 Location Gold Coast, Australia Its fine to leave it on though i mean if the computer is idling it will use less power.
19 Dec 2008 at 11:01 #25 gurusan gurusan Soldato Joined 2 Sep 2006 Posts 13,483 Location Forest Grove, OR, 'Merica its fine to leave it on, it doesn't really use less power though because it merely drops the frequency and not the voltage.
21 Jun 2009 at 01:58 #26 MrMoses MrMoses Associate Joined 23 Dec 2008 Posts 314 Location UK e8400 is a good Cpu only if you plan to Overclock it to past 4Ghz
