help, pc feezes after startup
1 Jan 2007
Hi Guys
Got a small problem, after our pc at works starts up it freezes. You can get onto the desktop and sometimes load a document up then the pc will freeze solid, no mouse no key's nothing, not even starting the pc up in safe mode helps it still does it then.
Any suggestions, is it perhaps a HD Fault?
Also when it does freeze the screen will go fuzzy and stutter around as well.:confused:
I don't know what the spec is, i was told that it has had new ram fitted? I think!
check the cooling, check the fans spin, no large amounts of dust, reapply the thermal paste.
