HELP! PC/mobo dead
1 Jun 2005
Switched the computer on this morning and .... nothing.
I've got a GA-EP45-Extreme.
When I switched the PC on this morning the BIOS stopped where it said iti was checking the memory. It all worked fine yesterday.
I pulled the memory out and put one back in a different slot. It worked for a bit and seemed to start up. But unfortunately, numpty here then put the other meory stick back in and now nothing - in any combination of slots or memory sticks (I've tried other spareones I ahve as well).
Depending on the memory slot, the PC starts up, the vid card fan whirrs, but the CPU one doesn't and it just stays there. Or, it starts but then switched itself off.
Anyone got any advice?
The Giga manual is of no help whatsoever in understanding what all the LEDs, and digital displays are showing me...
I figure it is a mobo problem.
Edit
Could it be the PSU? I got a pretty cheap Jeantech one.
Doubel thread form the Mobo sub forum, but I am desperate!
Assuming you havent knocked any wires out, it could well be the PSU or memory. Have you a spare PSU to try? You need a mulitmeter to test your existing one
