help. Pc will only post with one stick of RAM
27 Oct 2003
Belfast N.I
As per my thread here... I bought new RAM for my aging 6700k system to tide me over until a Ryzen upgrade later in the year.
With the new RAM pc will only POST with one stick. Any ideas?
Thanks!
CORSAIR VENGEANCE RGB PRO BLACK 32GB (2X16GB) 3600MHZ AMD RYZEN TUNED DDR4 MEMORY DUAL KIT
My Motherboard is a Gigabyte GA-Z170X-GAMING 7 INTEL Z170 (SOCKET 1151) DDR4 ATX MOTHERBOARD
As below RAM support according to OCUK product info says max speed supported 3466 :S
Chipset Intel® Z170 Express Chipset
Memory 4 x DDR4 DIMM sockets supporting up to 64 GB of system memory
- Dual channel memory architecture
- Support for DDR4 3466(O.C.) /3400(O.C.) /3333(O.C.) /3300(O.C.) /3200(O.C.) /3000(O.C.) /2800(O.C.) /2666(O.C.) /2400(O.C.) /2133 MHz memory modules
- Support for ECC UDIMM 1Rx8/2Rx8 memory modules (operate in non-ECC mode)
- Support for non-ECC UDIMM 1Rx8/2Rx8/1Rx16 memory modules
- Support for Extreme Memory Profile (XMP) memory modules
Resolved -
I had tried going from 2x 8 to 2x 16 a few times with no luck. Going to 1x 16 then 2x 16 and everything booted just fine in dual channel.
