Hello water cooling gurus,
I currently have a ThermalTake Tia Chi super tower with built in water cooling for my CPU, which I'm happy with sits at idle at 30-34 and load at 38-40, which imo is good
But I would like to add my gfx card into the loop as well, I think it shouldnt affect the temps too much and I'm getting fed up of the noise the fan on it makes, the card is a pci-e Ati 850xtx (Cant remember if its a PE) but its a single slot card if that makes a difference to the mount holes at all...
The piping my system came with is 8mm OD and 6mm IN I got some spare but will buy some more if needed
I was looking at a danger den Maze 4 GPU block but it comes with 1/2" fittings so would I need some kind of adapter to make it fit my piping?
or I found a "Zern GPU Block" on another site which comes with 10/8mm compression fittings, would this fit straight on?
So if someone could point in the direction of a block that will fit and some piping adatpers (if needed) I'd b very happy
Cheers,
Mac
Cheers,
Mac
