It would drop the top slot to 8X I would have thought.
So 8X/8X/8X across the three slots.
10-15c is pretty normal with sli/xfire. Board spacing helps a wee bit, but get a fan beind the cards such as an antec spotcool. Not elegant but it's cheap and it works.
I had temps like that in SLI 2x gtx660ti, stock cooling, top card going up to 70 esdily and bottom at 60. Still everything worked nice, this was on matx board so no space between cards at all.
Theres some other little points about the UD7 you should be aware off.
• No internal GFX solution as it doesn't pass the CPU's built-in gfx signal to the rear backpanel despite being a Z68 chipset.
• No PCI-E3.o support if you add an Ivybridge CPU, the NF200 chip wont pass the signal through so is PCI-E2.0 only.
Yeah the AIR540 would be 100% spot on if you could do that with 3.5"drives. I discovered this too when making this here. Really wanted the two SSD's to be on show but had to relent.
