help picking case fans
1 Jun 2014
I am looking in to upgrading my stock b case fans , I am considering Corsair with rgb type , most importantly I want maximum air flow , two for intake and one exhaust , price not really bothered .
If you just want max airflow, the Noctua Industrial PPC fans are pretty insane.
If you want the best balance of quiet vs performance, then the standard Noctua range are about the best.
If you want some semblance of quiet, plus RGB, but still with bloody good airflow then go with Corsair's ML series.
Just my opinion based on my experienced, YMMV. The biggest factor (in both noise and airflow) tends to be whether you have particularly tight mesh, filters, grilles or radiators up close against your fans, or not. Recently I simply removed the metal grille from the intake cover of my case (Enthoo Luxe) and within a minute my loop temperature dropped by just over 5ºC!!
your p300 case already has pretty decent fans, i wouldn't change them out.
add to them yes, but no point changing them.
Not fussed about price, Noctua or BeQuiet. pfffft about RGB, do your lighting separate.
Decent fans > fancy fans, choose one.
As others said, Noctua or BeQuiet are best, but if you don't want to waste tons of money I can recommend Arctic fans as well.
