So I've had my amp for a long while, I had everything set up perfectly and everything was great.
But then Christmas happened!
And some inconsiderate **** decided to buy me a 3d blu ray player which is causing me great stress in trying to get to work properly.
So I had a normal blu ray player before and i thought a simple switch over with the same HDMI cable would, using the same inputs into the amp etc. work but no... I'm not getting any video or audio from my TV...
I've checked with the same HDMI cable on another TV (Without it going through the amp) and it works fine. I've looked up online and it does say this amp is 3D compatible but I've read in the blu ray player booklet that that shouldnt even matter and I should be getting a picture....
The Amp picks up the 3d blu ray player at first when i turn it on the HDMI light comes on, but then after about 2 seconds the HDMI light turns off again...
Im stuck please help
