- 28 Apr 2014
Hi guys, a major problem with my newish build
It contains the following
Case: Inwin901
MB: ASUS Maximus VI Impact Z87 ITX
CPU: i7-4770k (not overclocked)
GPU: Asus GTX 770 2GB
RAM: Cosair Vengence Pro 16GB (2x8GB) DDR3 1866
PSU: SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply – Black
Hard drives: I have 2 x 500GB HD and 1 x 250 SSD
Intake Fan: Corsair AF120 Performance Edition 120mm
Cooler: Cosair H60i
OS: Dual boot with windows 8.1 and Ubuntu 14:04
Even on boot the bios shows a temp rising to 66C and using windows 8.1 just web browsing & using excel the temp can rise to 88deg! The MB temp is showing 28C and GPU is showing 36C
Ubuntu shows lower temps as less drain on the CPU and right now I am CPU is 51C, nothing running but Chrome.
I have checked the fans and all are installed correctly and air flow the correct way. The CPU is idling at 1%. CPU fan @ 2340RPM. The cooler is attached correctly, nothing loose, unless I made a mistake on the build.
Now I am aware that the case is a bit of a disaster for air flow, but temps that high? Its strange that its just becoming a problem now as a months ago I had no issue and was playing Crysis 3 on high settings
Any thoughts??
Case: Inwin901
Cooler: Cosair H60i
Any thoughts??
