Has anyone just been able to send a single item back from a system they have bought?
As i don't fancy sending the whole lot back seeing as i spent most of last night and today so far sorting out windows to the way i want it.
I might need some help soon too as i set the system to default and lost the overclock settings that ocuk had put on the system.
plus i need to install a couple of intake fans to the front of the 300 case and i have no idea where they will plug into on the motherboard or psu if i have to.
You wont need to send the system back, Give me a call on the system support line and I will replace the card for you.
We are sending gfx boxes out now for this reason of swaping out products instead of having the whole system back which takes longer, its up to the customer if they feel ok to change the card.
Yeah, I would 95% blame transit for the damage to the system, because im 100% sure the system was tested before it was sent out. What company is stupid enough to send out something like this, without even making sure it works properly?
