**** HELP PLEASE partition size?****
23 Dec 2009
HI i have just brought 2 Western Digital Caviar Black 1TB drives and wanted to know what size i should make the os partition size going to be putting xp on it?
Also what other partition should i put on it and the other drive? and if i got to win7 what os partition size then?
thanks for your help guy,all the best for the new year
With 1TB to play with, you have quite a bit of room :p I would normally make them about 30-40GB which allows plenty of space for the OS and program files.
If you are going to be upgrading to Vista or W7 at some stage then I'd make the OS partition around 60-80gb, will save you a major headache in terms of expanding the partition at a later date.
