Help Please
12 Feb 2006
Surrey
i get this messege when i shut down, and now when i start up:
"the instructions at "0x77d4d3e6" referenced memory at "0x77d4d3e6". The memory could not be wirtten.
click on to terminate the program
click cancel to debug the program."
The title is explorer.exe
Anyone know what this is and what i do to fix it?
thanks guys
bledd. said:
run memtest
give this one a try first
http://hcidesign.com/memtest/
then the dos one if that doesn't find any errors!
i have ran that, and i get a lot of problems. Many messeges saying memory error detected copying between word pairs# then it says loads of numbers, this happened 4 times in a matter of 5 minutes.
On there website it says that means the RAM is bad. Is that true? if so how do i fix it, or do i need to get a replacemnt from the company, i guess this comes under life time warrenty with them yes?
are you overclocking?
you could try upping the ram voltate in your bios a bit and see if that sorts it out :)
Bony Maloney said:
I see that you have 2 ram sticks in your sig. Try pulling them one at a time and re running memtest to establish which one if not both is bad.
well i ran 2 memtests at a time and 1 of them was 100% for the 5 minutes that i tested, and the other was the one having all hte problems.
No im not overlcoking them one bit.
How do i up the voltage?
well i've changed the settings on the bios back to auto, they were what the RAM said it could do so i dont understand the problem, but anyways the test so far hasn't shown any problems since the change to auto.
run memtest overnight if you can :)
