Specs are as follows:
Gigabyte GA_965P_DS4 Mobo
Intel Core 2 Duo E6300 1.8Ghz - Currently Overclocked at 2.5 (but probably could go higher) with a Scythe Ninja cooler.
4 GB Geil RAM - 2GB initially then put more of what I thought was the same in, but now it appears I've got 2x PC2-5300 (333Mhz) and 2x PC2-6400 (400Mhz).
A 256MB X1800XT Graphics Card
SB Audigy
A Lian Li PC-7 Case with a Seasonic S12 430W Silent ATX2.0 Power Supply
250GB IDE Hard drive
Now I've been thinking of upgrading slightly -
I'd like to get a 5770 Graphics Card and a 1TB SATA HD and install windows 7 at the same time. I think I'd probably get a 650W PSU as well to run it all properly.
I bought the system 3 years ago with the intention of OC'ing it, but never did. Now it wont run a new game I got, so I decided to give this OC'ing game a shot. Here's what I got initially - Excuse the 19hour time trial, I got struck down by illness and let it go on for longer than I expected!
I'm a little disappointed at what I think is a high temp for the minimal gains compared to what others are posting on here. Once I get a new PSU to go with the 5770 I'll cut some holes in the case to reroute the wires, but I can't see the temps going down much.
What would you gents advise trying now? I'm a little concerned about the differences in my RAM, what effect would that have?
Thanks
SB Audigy
Thanks
