Help please!
5 Dec 2008
Buckinghamshire, Marlow
Hi, i just received all the components in my sig.. and have put it all together.
Now i have two problems..
Monitor displays "No signal" and turns off
and
When i press eject on CD tray it will open and automaticly shut by itself... pretty fast.
Any idea whats causing these problems?
You using crossfire at the moment? Pull a card out/try each on their own.
Reset the bios, try one stick of ram in all the slots/try the other stick/repeat.
Do you recon this could have anything to do with the processor..maybe its been moved or something.. because i had a little trouble fitting the cpu cooler..
Coolers usually are a bit stiff to fit, its normal, or is the titan fenrir a clamp through the back jobbie?
You got ALL the power cables connected? Including the 8pin atx.
Just realised the gfx card fan is making a pulsing huming sound (thought it was the cd drive at first)..... maybe this is the cause of the problem..
Erm, dont know if this is a problem but.. im using a 8pin power cable which came with the powersupply.... to connected the gfx card to the powersupply
Do both graphics card make this pulse/hum noise, can you see the fans spin on them? The noise could just be the air, did you use standoffs between case and motherboard.
I'm running out of ideas.
When you reset the bios did you place the cmos jumper back on correct posistion, if it uses one?
Pull the power from the DVD drive and harddisk and boot.
Got access to another pc to try swapping bits.
"When you reset the bios did you place the cmos jumper back on correct posistion, if it uses one?" Yes
"Pull the power from the DVD drive and harddisk and boot." Tried :(
:( hope its not a fault in the graphics card itself :( :(
one last suggestion.
Pull the CPU out and look carefully at all the pins, look down the rows for any bent/broken ones.
You did mention something about it moving?
Also check the contact area of the thermal compound/does it look like its made contact?
Last thing is to find someone to swap parts around.
I'm all out of ideas now, sorry.
