help please :(
22 Mar 2009
Cornwall
ok, got a pc bundle here :
ASRock G41M-VS3
E5700
DDR3 1333MHz
put it all together and all was well. BSOD whilst installing windows, which was odd. anyways windows went on, but keeps BSOD.
thing is, the CPU should be 3GHz, but its running @ 1794MHz and Ram should be 1333MHz but is running at 800MHz. everything in the bios is set to auto. any ideas?
Is the voltage set incorrectly? I'm not sure what the correct vcore is for that cpu, but it sounds a little like it's not getting enough volts.
that wouldnt affect the speed or the multiplier.
well i did what i was told on my personal build and updated the bios, and guess what, now the multiplier is now no longer locked at X9
its now X6 :mad: really annoying me now.
