- 15 Jul 2013
- Barnsley
Hi was using my computer as normal doing muon1 and rc5 72 all temps where in the normal range CPU (amd 6100 @ 3.9ghz) running at 50 degrees and my you ( xfx 7870 Tahiti @stock) normal temp of 89 degrees ( I know this is hot but contacted xfx and said under heavy load like bitmining normal temps can be from 70 to 95 degrees)
To cut a long story long my pc just stopped no bsod no artifacting just stright off and will not turn on again. Being a petrified that it my be my psu while it does feel a little hot but I am not sure why it has happened now seen as I have been doing the same thing for well over a month now with nothing bad happening. (psu g7 880w )
Any advice would be great
