Help please !!
25 Oct 2013
I have a problem I am totally clueless on and hope someone can help me with.
A year go I built my own pc (my 2nd) and have had no problems with it until today.
The mobo is an ASUS Rampage V edition 10. I have been using the included Aisuite 3 to control the fans until after a win 10 update today it stopped working and so did one of the fans.
I d/l an updated version off the ASUS site but when it restarted during installation my keyboard and mouse stopped working - leaving me staring at the windows login screen.
I have tried plugging a simple usb keyboard in but even this won’t work other than if I use the safe boot button on the mobo to get me into the bios setup - but when I exit this the keyboard stops working and I am left staring at the login screen again. So totally stuck at this point.
The good news is all the fans are working !
Any help would be appreciated
This has been caused by the last monthly Microsoft update that has broken AI Suite 3. The services should still be running in the background, but the front end to control it won't come up.
The fix is to either uninstall update kb4056892, or update to the new AI suite beta. There is info in this thread with various download links (depending which one is up at the moment as they are all getting heavily used).
I've just installed it on my Z87-Pro and it does fix things, but you will have to redo all your setting and you get a changed UI.
To recover your no keyboard situation, you may have to boot into safe mode and either use a restore point, or remove the old AI suite and install the beta version.
Edit: Here's a link to the Beta AI Suite on the Asus download storage site.
Edit 2: Final version is here.
Thanks for that.
Problem is I have managed to get to the recovery screen but when I go to the startup options screen and hit restart - I don’t get the 2nd screen that lets you choose an option I.e. safe mode - the pc just hangs . Then I reboot and I am back to the no keyboard or mouse problem.
I have tried using the restore point but it fails.
Looks like my only option is to reinstall win 10 which is a bit of a disaster.
Tried that also - fails.
Reading the thread you linked someone else reinstalled aisuite after the win update like me and lost all usb in Windows but got it working after changing in bios but I can’t see how - any ideas ?
Just need 1 usb working in Windows to get past the login
Wonder if the ps2 port might work if I got an usb adaptor ?
Bit of an update for all those siting on the edge of their seats...;)
Found an old ps2 mouse which by using the os keyboard got me past the win 10 login screen
I uninstalled aisuite 3 but still no luck - it refuses to see my usb mouse or keyboard
Have also rolled back the win 10 update but again no usb mouse or keyboard
I had a similar issue recently, in the software section of the ROG forums there's an AISuite cleaner utility - completely uninstall AISuite using control panel, reboot, then run the cleaner. Reboot one last time and install the latest V3 beta of AI Suite from the ROG forums (3.00.10 beta) - worked for me at least
Au suite3 now works but mouse and keys still no.
Win10 shows an error on various usb hubs but hitting repair just fails to resolve
Any ideas ? Wasted so much time on this now
Yes - I have now realised the front panel usbs work but the ones on the back (i.e straight off the mobo don't) - once I get into windows.
Thx
Deleting the usbs showing the errors and rebooting did the trick ! Didn't need the drivers.
That's most of a weekend I wont get back
Thx
Glad you got it sorted. MS broke it, but I bet that Asus were doing dodgy things in their code as well. The fact they brought out fixes quite quickly showed that there was stuff going on in AIS 3 that were a bit fast and loose.
