Hi all
Dont know if this is considered the correct section for this , sorry in advance if it is .
So my set up was working ok , i decided i wanted another m.2 in there for games to run a bit quicker , i installed it and everything seemed fine . then the comp just froze up so i hit the reset button now the thing wont load and i get the error B1initializedkibrary failed 0xc0000001 .
From what i can see its a windows issue , but i cant find me recovery usb stick , and the ony other pc i have is a chromebook , which you cant install the windows media tool on to make another .I have found a post saying you can use the chromebook recovery utility to burn an image to a usb and boot from that , but its not working , the screen just flashes a few times and then goes back to the bios .
Is there a way to factory reset from within the bios ?
Anyone know of any tricks to get me back into windows ?
im pulling what little hair i have left out !!
My mobo- asus hero maximus x
i7 8700k
windows 10 - upgraded to 11 - had no issues with the upgrade
Regards
Tony !
TYVM
i7 8700k
Regards
Tony !
TYVM
