help plzzzzz
I do not believe you have watercooled graphics cards and are unable to find google.com.
Troll.
Ah, why not. EVGA precision.
hi just asking wich is best i thought the evga 1 was not sli unless i was registered evga ueser ps i am full water lian li v2100 plus (hand TIG ALLOY MODS BY ME RAD MOUNT PSU BOX ) tagan 1100 bz 2x black ice gtx 360 rads danger den tdx 1366 i7 not 775 1 laing d5 1 alphacool ddc 1 ek 150 res 1 ek 250 res i7 920 foxconn blood rage ocz reaper pc3 14400 OCZ3RPR1800LV6GK) 2x bfg gtx 280 h2oc x fi titanium 1/2 tygon tube fluid xp blue / green
Perhaps not a troll then. If you're capable of wig welding you're probably capable of typing coherently, please do so. Full sentences are much easier to decipher for those of us who struggle with unbroken text.
You may well be right, it might not cope with sli. The solution would be to overclock them individually. Since in sli they run at the same speed, note down the slower stable speeds of the two cards. Use nibitor to change these speeds in the card bios then nvflash to write the bios to the card, then write the same bios to the other card. Boot windows and set up sli, probably best to test it again.
The advantage is in avoiding software, since software overclocking is messy and sli is inherently a bit hit and miss. This approach will work much better.
Welcome to the forums
