Help - Power Cables
Caporegime
20 Oct 2004
Hi,
I've lost the power cable for my hard drive, so went online just now to find a new one. Which is harder than I thought. The cable am looking for goes to what looks like an old PS2 type connection? Any ideas?
Hi,
External hard drive?
I'm pretty sure internal is only molex or sata
No its the 12v power adapter plug for the exeternal HDD. Normally it would just be your normal plug in type but this is well similar to that of a PS2 connection but for power.
Can't think of its name, therfore struggling to buy one!
much cheaper, safer and easier to buy a new enclosure probably. just check if its IDE or SATA.
Well the HDD pictured is IDE
@Op
So does this cabple go directly into the wall or does it go into converter? If so, is the other end the same?
@Op
Just a random picture from google.
Its SATA, will just buy another enclosure seems the cheap way.
Surely this should have been posted in the 'general hardware' or 'hard drives' forums?
