HELP QUICK PLEASE RAID PROBLEM
15 Aug 2003
Christchurch.
I have just cleaned up some of the dust etc.. plugged everything back in. It post gets to my sata raid screen- it now detects 2 74gb discs ide slave 3 and ide slave 4 (instead of 1 healthy 150gb drive) and now wont go any further -
Verifies DMi Pool Data then disc error has occured!
Is this a rebuild system or can i get it to see my raid again :confused:
i have looked in the bios and they are marked as 3 & 4 slave drives looked at changing them but couldn't.
I have i other sata 2other ide drives a 2 optical drives and one floppy. The only drives i have plugged in at the mo are the 2 sata drives and the 2 optical drives
Help!!!!
Were you using SATA 3 & 4 previously?
Are ports 3 & 4 configured as RAID ports in the BIOS?
Can you access the RAID BIOS?
