Help RAM Decision
19 May 2004
Horsham, West Sussex
I'm about to receive the following
Gigabyte GA-MA790FXT-UD5P
Phenom II 955BE
On Friday night I ordered this RAM
http://www.overclockers.co.uk/showproduct.php?prodid=MY-109-OC&groupid=701&catid=8&subcat=1387
Then I spotted that it runs at 1.8V rather than the normal 1.65V so was a little concerned that this is actually lower speed RAM being overclocked - hence the need for the higher voltage, epescially because they do this one
http://www.overclockers.co.uk/showproduct.php?prodid=MY-178-OC&groupid=701&catid=8&subcat=1387
I was wondering whether I would be better off with one of these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-024-PA&groupid=701&catid=8&subcat=1387
or
http://www.overclockers.co.uk/showproduct.php?prodid=MY-042-GS&groupid=701&catid=8&subcat=1387
I tried to cancel the order whilst I consider it but there is no cancel option.
So I sent a WebNote and tried to call them in the morning but couldn't get through before I had to go out.
Anyway despite sending the WebNote in plenty of time they didbn't read it until 3:30pm after they had processed an sent it out.
So my dilemma.
Although OcUk say I can send it back I'm tempted just to keep it and avoid the hassle of RMA.
My board MoBo can only support upto 1600 anyway and I think the OCZ can reach that pretty well.
What do you think?
Cheers,
Nigel
