Help required: Ikea castor spindle diameter
21 Aug 2003
Essex
I know there are a number of ikea office chair fans on the forum.
Before I drive all the way to the store. Would someone be kind enough to measure the diameter of the spindle that is inserted into the chair? They are the push in type with a sprung steel ring.
My lodger has a chair with plastic wheels. After sweeping the floor today I noticed they are completely ruining the finish of the floor. So I am after a set of those nice rubber coasted ones. It isn't an ikea chair as far as I know.
It's ok the ikea casters fit bang on. You can all rest easy.
Repaired the lacquer with mayonnaise. Good stuff :D
