Help Samsung 840 Missing Space
did you clone your old drive to it? if you did did you check the box to make use of all available space in the cloning program?
Thanks for the quick responses. I didn't clone my previous drive. I've just disabled hibernation and managed to claw back a bit, now showing 54.5gb. Just another 20 odd to find, any other good suggestions lol!
reduce your pagefile,if your running 16gb of memory or 8gb your pagefile will be asmuch as your memory amount
so reduce it to 2gb imo,that will save you another 14gb or 6gb of ssd space
Control Panel, System
Advanced System Settings
Click Settings under performance
Goto Advanced Tab
Click Change on Virtual Memory
Click Custom Size and alter to how you want to set it.
