Help - Server drive completely out space
Man of Honour
17 Oct 2002
Retired Don
Hi guys,
One of our old customers has called because their domain controller has gone down.
We've looked into it and their drives are completely out of space.
They are running raid 1 I think, but need to double check this.
What would be the best (quickest) way of moving the entire load of data, as it is, eg imaging, onto a new, larger raid array in the same server?
Cheers,
Mal
Would the following work:
Install new Raid controller with 3x new drives, and setup an array.
Use Ghost or Acronis image the partitions from the old array to the new array. I know with Ghost you can specify a new size for the partition, but I have a feeling it only sees the first partition on the array?
Is it just a DC? Can you clear enough space to get it running again?
It's an old, bad setup. It is DC, DNS, DHCP and user file and profile storage!
They have plans for a complete new setup, but we need to do something in the mean time.
It has a 10GB C: partition, so we really need to do something!
Have just been able to get to their site, I didn't realise the drive was at least partitioned off, so it is only the C: that is out of space. There is loads of space on other partitions.
Am going to take a full backup, and then use Partition Wizard Server Edition to resize the partitions and extend the C:.
User data isn't on C:, there is nothing more we can move off CL, it only has Windows etc on it. The numpty who set this server up years ago used an 8GB C: partition!
Well 8gig should be more than enough for a (properly set up) server. Is the pagefile on c:? That's usually a quick fix
Clear down any update uninstallers as well.
Heres a batch I use to get rid of that stuff;
c:
CD %WINDIR%
Del kb*.log
For /F "usebackq delims=" %%W in (`dir /d /b /ah $*.*`) Do RD %%W /S /Q
pause
This may be stating the obvious, but windows installations dont just expand with heat or anything - something has grown to take up the space, you need to find what it is and deal with it
Is it SBS? Exchange lives on the C: partition by default if it is. Very easy to move.
Otherwise take a backup of the C: partition then resize it with Acronis.
Get TreeSize on it (an older version, new one says gtfo on Server) and find out where the space is being used.
