Help setting up Eyefinity.
17 Oct 2011
I have my eyefinity setup (3x 24" monitors) but i really do not like my desktop using 3 screens. In Windows 7 you can go into Appearance and Personalization\Screen Resolution. I can set my middle monitor to display desktop only and be able to use the left and right screen freely. The only problem i have is my games can only be played at 1920x1080. As appossed to eyefinity resolutions of 5760x1080 etc.
Is there a way i can set my desktop to my middle screen only. Stil use the left and right screen. And when i play games it will detect i can go higher than 1920x1080?
The way I do is it make 2 presets in CCC, one eyefinity and one extended desktops. Then you can set shortcut keys(hotkeys) in the preferences of CCC to select the preset u want. Easiest way i have found upto now
Here is a pic showing the setup, remember when you are doing your presets change all settings from within CCC, dont go using the windows control panel thing.
