- 25 Nov 2011
Hi.
I own P77P5 - LX motherboard, i bought two OCZ Agility 3 SSD. I plugged them into motherboard with SATA III cables. They were detected fine.
First attempt, entered BIOS and chose RAID over IDE. Then booted Windows 7 -> Control panel -> Administrative Tools -> Disk Management. I setup the two drives as striped in NTFS format, they change colour and become one. I insert Windows 7 installation disk in CDROM drive, then reboot. During install i cannot pick my new striped dynamic drive.
Second attemp, after reading someone's post which stated; separate the drives, install W7 on one then strip it with the other. I followed this procedure after separatin the drives, making them 'unallocated'. After install i try to strip them, option is gray.
WHAT AM I DOING WRONG, PLEASE ADVISE.
Thank you.
Thank you.
