I hope I am on the right track and asking the right question here.
Right, I have just typed and then removed a load of cack.
What I am trying to do, is simply have LAN 1 here
and LAN 2 here
But for me to be able to join them together.
Ideally, I would simply use an ethernet cable between the Modem/Router and the switch or second router and sure, this will work a treat, however, for this project, I am forced to use wireless.
Now, I have not tried this before, or rather I did think but never took it further than the thinking bit.
From what I seem to gather, is that on both routers, I need to connect with the MAC, one being a Master and the other being a client, or slave.
Now, my main Router does indeed have the gubbins to let me do that, however, none of the other routers / Modems seem to have it, of they are not compatible.
Is there a very simply "Childs play" guide to doing this, or am I once again peeing into the wind?
Thanks.
and LAN 2 here
Thanks.
