- 24 Mar 2008
When I decided to put the 2nd card back in I swapped them round at the same time. It appears to be a bit better now. No glitches in Trackmania and only minor ones in Quake3 (and I can run that single GPU if need be). I am downloading Crysis demo now to try that out.
Also noiced that after re-inserting the SLi birdge there was a rythmic interference running down the screen - the SLI bridge (the plastic part) was touching the heat sinc on the GCard. I pulled it away and this stopped.
Might see if I can get hold of a rigid SLi bridge instead of this flimsy one ASUS have given me.
