Help: Software Recovery for Laptops
14 Mar 2010
I have a laptop and it has a partition where the recovery is on, the problem is the laptop would not load and keeps re-looping.
It gives you the option to start on safe mode and what not, but after selecting it, it will reboot and keep will not load.
How do I access the recovery from booting and continue straight to a full recovery?
Any help would be much appreciated.
Thanks
Depends on the brand of laptop. Usually a function key is pressed on startup such as F8 which takes you into the advanced boot menu and from here you can start the factory recovery.
As the computer starts, press F8 (Xp is F11 i think) to get the Advanced Boot Options menu
Press the Down Arrow to select Repair Your Computer and then press Enter.
Bear in mind though you'll need to backup all your files before reseting.
