hi there.
just bought a new system
the mobo is this
http://www.foxconnchannel.com/productsDownload_motherboard2.cfm?pMotherboard=6100K8MA-RS
basically this is my system:
amd athlon 3000+
512mb RAM
maxtor 200gb HDD
XP pro with SP2
programs
nero
bitdefender 9 pro
MS office
spybot
power dvd
limewire
zonealarm pro
msn 7.5
ok i started by uninstalling ZA but it still kept resetting. i then went into cp then power options and made sure it isnt resetting cos of this. then checked cp then system/advanced/startup and recovery/then unchecked auto restart, and i dont think its reset again with that unchecked.. so anyway i checked it again so i can solve this problem!!!
ive tried going into the BIOS to make sure its not set in there to make my pc go off. ive downloaded speedfan and all my temps are very good. ive downloaded memtest and used it for 20 mins with no errors. ive tried uninstalling a couple other progs with no luck.. ive tried downloading latest drivers for my mobo..ect.
its reset 3 times today.. 2 of those times (being the last 2 times) its reset just as i went to play this game.. http://www.dragongamez.com/castlebattles.htm
im only running 1 firewall (zonealarm) 1 antivirus (bitdefender 9)
helppppppppppppp
the mobo is this
amd athlon 3000+
512mb RAM
maxtor 200gb HDD
XP pro with SP2
programs
nero
bitdefender 9 pro
MS office
spybot
power dvd
limewire
zonealarm pro
msn 7.5
helppppppppppppp
