Help spec me a case
10 Jun 2005
Hi all
I am upgrading my system and will be purchasing a 290X so would like a case that has decent airflow as these cards can run warm but at the same time I would like something fairly quiet as the PC is in my lounge.
I am looking to spend up to £100 and have looked at a number of cases including:
- BeQuiet Silent Base 800
- Phanteks Enthoo Pro Mid Tower
- Corsair Carbide 330R Silent Mid Tower
- Fractal R5
Even after looking through all these in terms of reviews etc. I am still none the wiser.
The problem is trading off sound with cooling it seems. The Phanteks is apparently excellent cooling but can be fairly loud whereas the Fractal R5 may be quieter but run slightly warmer.
Corsair Air 540 , just got one last week very big case well build and would even fit the longest 290x card.
The stock fans are ok but have a grinding noise so i replaced with some Aerocool DS 120mm ones very quiet now...
