HELP??? Stiker Extreme Overclocking (Beginner)
6 Aug 2007
Hi
Has anyone overclocked the Striker Extreme Motherboard and if so can you give me pointers/guide???
I'm fairly new to overclocking so would be grateful if you could keep it as simple as possible.
My system details are below:
Asus Striker Extreme nForce 680 Motherboard
Intel Core 2 Quad Pro Q6600 2.40GHz
BFG GeForce 8800 GTX OC 768MB GDDR3
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB)
Tagan TG530-U22 530W ATX2.01 2Force SLi Compliant Silent PSU
Cooling:
Asus Arctic Square CPU Cooler
2 x Sharkoon Silent Eagle 2000 - Case fan - 120 mm.
(If you need to know anything else please let me know)
Going to upgrade the RAM soon and put another GPU in but I'm not in a hurry. Any recommendations on good Ram with my set up and overclock compatabilty would be useful too.
Also using Nvidia ntune to monitor system temps my GPU is runnning about 65 degrees, is that normal???
Thanks
:D:D:D
