I’m setting up my workstation at the moment. Specs are as follows -
12900k
MSI Z690 Pro
64Gb Vengeance 5200 (2x 32gb)
2070Super
RX850w
Arctic LFii420mm
No matter what I set the damned thing to it thermal throttles in Cinebench. I don’t want to start loading too much other software on until I’ve got it working properly hence just using the cpu standard benchmark.
I can lower the power limit, but then it hits power throttling and I lose a good chunk of performance.
It doesn’t seem to matter what I set the core voltage or LLC to, it just ignores it and chucks whatever power at it that it fancies to hit the clocks. Oddly enough although XTU says it’s throttling it doesn’t drop the clocks at all.
The cooler is mounted with the Arctic 1700 mounting kit. It’s definitely making good contact and I’m using Thermal Grizzly Hydronaut.
I know these things run hot, but surely it shouldn’t be hitting 100c within 2-3 seconds of a cinebench run? Especially on a 429mm AIO!
Is there some secret sauce setting that I’m missing in the bios (or xtu) that’ll help?
12900k
MSI Z690 Pro
2070Super
RX850w
Arctic LFii420mm
its stock no OC xmp enabled ddr5 and more worried about the spiking than the cinebench tenps though id like to reduce this for a small OC. MSI Tomahawk mobo with thermal grizzly lots of fans o11 evo case.
