- 30 Mar 2016
It is a new PC. After I finish install and boot, it stuck in b6. Need help.
which motherboard?
*edit* something like a rampage V extreme?
ok, that means the error is = "Clean-up of NVRAM"
I may be wrong, as I havn't had this error, but this is where the bios stores its settings, try clearing CMOS or switching bios
also google "Clean-up of NVRAM" and "ASUS" together and you should find others with the same issue. No doubt it can be caused by a few things so best to have a look around![]()
you tried to take the motherboard out of the case and starting it on a bit of cardboard or something else non conductive?
yeah, if you are down to bare bones and have tried flashing a new bios, tried reset etc etc I am not sure what else to suggest, having never had the fault myself I cant really offer much advice other than the basics.
sorry =(
