Help! Time for a Mobo/CPU upgrade.
5 Jan 2012
Caldicot, South-Wales
Hi forums,
I recently did a "small" upgrade in the GPU department from an AMD 7850 to a GTX 970 and it's done wonders in terms of performance. But now it's time to up the ante a bit more and do away with my sluggish i5 2500k.
I guess I'm on a £500 budget, or if that isn't enough I can stretch to £600. But the problem is I haven't been keeping up with the latest CPU news. I know if I want a worthwhile upgrade I'm going to have to get a new Mobo as well so I'm open to either AMD or Intel suggestions.
Specs at the moment:
Gigabyte Z77-D3H (Socket 1155)
i5 2500k 3.30ghz
GeForce GTX 970 4096MB GDDR5
Corsair Vengeance 8gb (2x4gb) DDR3 PC3-12800C9 1600MHz Dual Channel
Raijintek Themis Evo Professional CPU Cooler
Cooler Master Elite 430 Windowed Case
Thanks you in advance,
Dan
Get an SSD.
Your i5 2500K's not sluggish. Overclock it.
Frankly, only thing I'd be considering as far as upgrading is X99, but I can't see you gaining much over a clocked 2500K with a single 970.
