- 14 Jul 2005
- Birmingham
Is there a memtest alternative that runs from windows? I don't have a usb stick I can use.
Well maybe not but I paid for 3200 MHz ram so not great.
Is it normal for there to be a temperature difference when running the RAM faster?
Edit 22:55. With the CPU overclocked as per previous settings documented here, but the RAM on 2133 MHz, I do not appear to be getting the issue.
The XMP profile might be the problem. You need to test the RAM with Memtest. If it passes, you can get the desired speed without using the XMP profile.
