[HELP] Trying to return faulty components. [Returned, Thanks!]
I'm getting increasingly frustrated at the moment with my new components and the amounts of times I've had to explain the problem I'm having to several different advisors. I recently bought a complete new high-end (£1500 worth) set of computer components from OCuK, which was bought and paid for on Thursday. I recieved the parts on friday, very good up until this point.
However, on assembling the PC (taking EVERY precaution and anti-static measure possible), the system doesn't POST or get as far as BIOS, and the screen displays 'no signal input'. The motherboard displays the code 'AF'. All fans spin and power up, but that is a far as it gets. No further. Now, I have performed every possible diagnostic test imaginable, including and likely not limited to:
- Replacing CMOS battery after 30 Seconds
- Using the Clear CMOS function of the boards switch
- Using the 'CLEAR CMOS' settings with the motherboard bridge
- Re-seating the CPU
- Trying different graphics cards in different PCI slots
- Running with bare-minimum components
- Swapping out the RAM in various combinations, with different RAM chips etc.
- Tested the RAM and graphics card on other system (it works)
- Tested PSU on another sytem (it works)
I HAVE DONE EVERYTHING POSSIBLE. Except replace the CPU, which I can't do because nobody owns an x79 motherboard and CPU I can replace it with. Taking it to my computer shop is impossible because they do not stock x79 CPU's or motherboards because they are so expensive and not widely used still.-
I have spoken to an advisor on the phone, who has now suggested that I return both the CPU and the Motherboard as faulty components via an RMA request. I returned to the website and filled out the RMA return with this information, I then recieved an e-mail telling me to "try different RAM, it could be anything". The complete opposite of what I wanted.
I've already tried everything! And have explained this many times over! Why am I struggling to have my faulty parts replaced? I bought everything from OCuK because of the recommendations about service but so far I haven't seen much of it... This PC has cost me an absolute FORTUNE, and isn't even a week old!
I HAVE also contacted ASRock, who are yet to respond to my technical support e-mail, and don't have a UK helpline.
The parts bought and assembled (ALL from OCUK):
Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
ZOTAC GeForce GTX 560Ti "448 Edition" OC 1280MB GDDR5 PCI-Express Graphics Card
Asrock X79 Extreme 4 Intel X79 (Socket 2011) DDR3 Motherboard
Corsair Graphite 600T Midi Tower Case - Limited Edition White
Western Digital Caviar Green 2TB SATA 6Gb/s 64MB Cache - OEM (WD20EARX)
Corsair Enthusiast Series TX750M High Performance 750W '80 Plus Bronze' Modular Power Supply (CP-9020003-UK)
OcUK E2250SWDA 22" Widescreen LED Monitor - Black
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3)
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G)
Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (KHX1600C9D3K4/16GX)
TP-Link 300Mbps High-Gain Wireless-N USB Adapter (TL-WN822N)
OcUK Value DVI-D Dual Link M - M Monitor Cable (Black) - 2 Meter
Can someone PLEASE help me out here?
