What difference has it made to your temps?
I don't know never used the stock, its on a G3258 @ 4.4 think it hits around 60 running stress tests
CPU-Z now says F6 and the RAM is still at the same settings?
thanks!I don't know never used the stock, its on a G3258 @ 4.4 think it hits around 60 running stress tests
60 doesn't sound bad
The i5-K will run hotter when overclocked and on load. The Pentium-K has lower TDP.
Not that it should be an issue for a decent O/C. If it's a good chip.
