Hi,
I'm investigating a problem on my dads PC with WoW (just WoW, nothing else has issues) occasionally crashing, and have come up blank with virus scans, CPU temps (E6750, under 55 degrees running 2x superPI for 10 mins) and GPU temps (GTX460, 72 degrees in FurMark after 10 mins), but I did find some SMART problems on the HDD.
As you can see it's a WD 240 GB 7200 rpm and I think that's 14K reported hours on it.
The question is - how serious are these problems, and is this drive still healthy?
Cheers,
Simon.
Cheers,
Simon.
