- 14 Jun 2015
Good morning all,
Sorry for my first post to be begging for help but I'm totally stuck. As you can see I bought my graphics card quite a while ago and then followed it up by buying a motherboard, ram, processor bundle from OC a couple of years back - Can't recall the bundle name or find it in my orders! Argh
Anyway I'm looking to build a high end(ish) gaming pc, I'd ideally like to be running high end games on High/Ultra graphics with a decent FPS. I know it's what everyone wants but I'd ideally like to do it on a budget or upgrading my current system which I'm not sure can be done? I'm so out of touch with new pc parts I don't know where to start.
My initial thought is that upgrading my graphics card would be the best option? Was thinking something like:
https://www.overclockers.co.uk/showproduct.php?prodid=GX-204-OK
As said though I don't have a clue so I may be best off buying a whole new PC.
Any advice would be greatly apperciated! Please see build below, hopefully this is all the info you need.
Current Build: Radeon HD 5850 1GB GDDR5
2 x Kingstone HyperX Genesis DDR3 (9905403-199 A00LF) 8.00GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
Intel Core i7 2600K @ 3.40GHz Sandy Bridge 32nm Technology
Motherboard - ASUSTeK Computer INC. P8Z68-V (LGA1155)
Windows 8 64 Bit
Thanks again!
Mark
Windows 8 64 Bit
Thanks again!
Mark
