- 18 Dec 2008
I am a proud owner of 2 VTX 7970 x edition graphics cards. The stock cooler on them isn't very good, so when news of the KRAKEN cooler adapter came out I was over joyed. After installing the Kraken coolers something strange happened to my cards.
The first thing I noticed was the factory over clock no longer showed in MSI afterburner instead of 1050MHz it now shows 925Mhz on both cards. Memory clock now shows as 5500Mhz instead of 5700Mhz as well.
The Kraken cooler on secondary adapter didn't appear to work as the gpu temp shot right up in MSI Afterburner before crashing my PC. I have now replaced the original cooler and the temps are ok, but now now PC to freeze up when I use cgminer with the secondary adapter, and sometimes when the PC boots. Strangely 3d mark works perfectly with x-fire enabled.
I can't explain why the factory over clock has vanished just by changing the cooler on the cards. I need help is working out why my second card cannot mine for more than a couple of minutes before crashing my system now. Temps don't even hit 80c with the stock cooler before crashing.
I have now Purchased the OCUK Kraken 7970 but I am holding off installing it until I have sorted out my current problem.
My dream was 3 way crossfire and a cgminer monster system. Now I am a broken man full of sadness and regret.
