Hi there,
Looks like it is time to upgrade, I guess I have a bad card not sure. My Gtx480 started to loose Signal and restarts after gaming for no more than 20mins and I failed to find out why or what causes it.
I tried everything, from cleaning it to updating the driver to many other solutions which I found using our beloved "Google" and could not find a single answer to my issue.
However I noticed graphics card is running at 61c-75c without any load, hell its just running normally and only using the web currently and never goes down bellow 61c. While gaming it shoots from 89c-101c. I need advice on what to do.... (By the way I found those numbers using "SpeedFan").
Do you guys think it is a overheating problem? does it worth upgrading to a different card? I do have a small room but the windows are open and can tell you that I am freezing like no tomorrow and still does not help much.
Any advice at all guys? I am looking to upgrade to a better card at the end with a better cooler card if possible.
