Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
I am using Mac OSX and all of the sudden the drive is locked !!! (on the actual enclosure, the light is lit) How do I unlock it? Its not a password lock but i can't write files to it?
I googled and i found something to do with running terminal commands?
I cut and pasted this and it did nothing
All my photos are on there (I have backup), but my LR catalogue is in there, and so is the wedding i spent a week processing!
I can access it, i can see the files, i can't however do anything to it ! not even copy a single jpeg into it. If it try, it just hangs.
PHP:
sudo chflags 0 /volumes/*
sudo chmod a+rx /volumes/*
