I currently have the gear in my sig in an M59 mid tower.
I'd like it all quietened down a bit and am currently trying to decide between:
The Define XL
http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-FD&groupid=701&catid=7&subcat=1556
and R3
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-FD&groupid=701&catid=7&subcat=1556
I guess the main thing is the case has to fit the NH-D14
Other than that I basically want the one with the best noise:cooling
Initially I was thinking the XL, but looking around a bit people seem to favour the R3.
What do you think? Are there any better options in the same price range (up to about£90-£100)?
The Define XL
and R3
) M59 for before and after too
