hi guys this is my first post here so sorry if there is any mistakes.
my current pc is
intel i5 3570k cpu
asrock z77 pro3 mobo
2x4gb g.skill ripjaws ram
2x 120gb macbook hdd's in raid 0
1x 1.5tb hdd
radeon hd 6450 gpu
cit Jupiter case,
i recently started to get right in to my pc gaming but the hd6450 just doesnt cut the mustard. i get paid soon and im looking to buy a new gpu but im not sure which one to get?
im wanting to spend £150 max but preferably a bit less, also it has to be a amd gpu because that's what my mobo supports "correct me if im wrong," also do you guys think i should bother getting a better cpu cooler or just stick with the stock?
thanks nathan.
			my current pc is
intel i5 3570k cpu
1x 1.5tb hdd
radeon hd 6450 gpu
cit Jupiter case,
thanks nathan.
