Hello new member and beginner in to oc.
ryzen1600X ,mobo ax370 gaming 5, ram 2x8 team dark 8pak 3200mhz ,gpu 2x msi gtx970 running in to sli, PS corsair hx1200i. cpu cooler be quite dark rock pro 3.
Currently got oc cpu to 3.9mhz without touch voltage its staying on auto in bios and its cycle around cpu vcore 1.38v-1.404v cpu vcore soc 1.212v cpu vdd18 1.056v cpu vddp 0.888v-0.900v
ddr is xmp enabled and run at 3179mhz to 3204mhz at stress.
cpu temp iddle between 25C without load and go up to 46-48C when do stress, gpus are oc 140mhz on core and 500mhz memory just powerlimit is 110 no touch voltages at all.
So im need help to can hit 4.0 even max 4.1 on cpu already have trying but didnt understand how is work exactly adding voltages and do crash when trying some test and how much to add to cpu vcore for Herts up etc.
any help guide is wellcome thanks.
