Hi guys,
My computer simply will not boot, and I've tried everything I possibly can. Could anyone maybe shed some insight as to which component may be the issue here:
So I turn the computer on, it will post fine, when it comes to booting from whatever device is selected it will simply reset, post again, and then reset at the same point etc etc.
It doesn't matter what device I want it to boot from, whether it's a mechanical drive, ssd, or dvd drive. Even usb drives cause the same issue - it simply will not boot and just resets.
As I mentioned, it will post fine, I can access the bios without issue, and I can even browse around the hard drive or usb drives using the bios 'E.Z. Flash Utility' so I don't think there's an issue with all of the drives.
I've tried a replacement graphics card, and no graphics card and it does the same thing.
I've reseated the CPU several times ensuring it's all as it should be, and that the heatsink isn't on too tight.
I've tried every possible combination of the two sticks of ram, in each slot, together and individually.
I've simply concluded it's either the CPU, or the motherboard, but am not sure which. Is there any way to determine?
Thanks
Components:
2500k
P8P67-M Pro
AMD 6950
Thanks
Components:
2500k
P8P67-M Pro
AMD 6950
