EDIT/ SOLVED - See post #23 in this thread or TL: DR Windows Start Menu/Settings/Network & Internet/Network Reset
My Virgin Media fiber conenction has been a rock solid 550Mbps for nearly 1 year but today on my wired connection it's just 130Mbps. It is not the fault of VM because my phone still gets 550Mbps over a wireless connection so it must be an issue with my PC.
I've tried both ethernet ports on my mobo and checked for updates in the following places and I have zero outstanding updates:
Windows Update
AI Suite (Motherboards updating software)
Intel Driver & Support Assistant
I have no software running that is hogging the connection or anything like that and obviously I've tried rebooting the PC and the VM Hub, but as I said the Hub is actually providing the correct speed via wireless so I don't beleive there is an issue there.
Any ideas?
Windows Update
Any ideas?
It's pretty easy if you have a USB stick, you can simply boot to it and use it as a normal install from the USB stick, probably not worth it with what you've already tested (multiple machines) but it's there as an option
