hi all.
so new to forums thanks
i have 3x120mm
(Coolink SWiF2-1201 Retail 120mm - Silent)
http://www.overclockers.co.uk/showproduct.php?prodid=FG-010-CL&groupid=701&catid=2331&subcat=4
And 2x80mm
Coolink SWiF2-80P Retail 80mm - PWM
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-CL
With all 5 installed, it makes a bit of noise. 1 of em are on my cpu cooler.
So i wanted to buy a fan controller to noise down the 4 of em (those not on cpu)
But all i can find is fan-controllers with 3 pins.
So my question is. what are the 4th pin for?
And wich of the pins can i skip useing?
Cheers all
i have 3x120mm
And 2x80mm
Cheers all
